A special CLI command mode provides a set of specific commands that are different in operation and syntax from the standard switch CLI command modes and the commands available in them. For example, a set of CLI commands that configure services on a Virtual Machine (VM).
Special CLI command modes can be hardware dependent. For information about feature support, see Fabric Engine and VOSS Feature Matrix.
The following table describes the special command mode.
Special command mode |
Command mode navigation |
Command to access mode |
Prompt displayed in mode |
Description |
Fabric IPsec Gateway |
Accessible from Privileged EXEC |
virtual-service WORD<1-128> console Note:
Type CTRL+Y to exit the console. |
FIGW> |
Configure services like IPsec, fragmentation and reassembly, and to manage the Fabric IPsec Gateway VM. |
